Sir Zulfiqar, i have a problem with my charade on cultus engine with MX17 auto transmission, now the issue is with auto trans mission
today i found time and went for silencer work after the silencer being fixed, i return to home, as i went further i noticed a weird sound from the gear box suddenly feeling power loss, as i came near to my home the car was not moving at all, 2, 3 times i shifted it from parking to D, no power on wheels at all, so i turned off the engine and checked ATF level it was on a bit higher side, then i started engine the ATF level remains at that level, means that its not decreasing at all as in normal auto transmissions do,
now sometimes it engages the clutch sometimes it doesn't, but as i press accelerator in parking gear a weird sound comes from the gearbox,
now what should i do replace the ATF or it does need a transmission repair?
