OriginallyPosted by Xulfiqar
donot adjust this - this is only adjusted ONCE when a new mastercylinder is installed - if you push it forwards you will losepressure in the clutch as it wont have full stroke anymore.
Yourproblem is loss of pressure at the slave cylinder or a worn pilotbearing.
pilotbearing and piston in slave cylinder already changed before sixmonth, can soft line be the culprit ?
Xulfiqar Bhai,
Yesterday bleed the entire clutch system change the kit (FIC Japan)of master clutch cylinder and slave cylinder also the mechanic enhance the size of push rod of slave cylinder up to 1/2 inch, in test drive gradually gear shifting become normal.
Today morning I start the engine and press full clutch and try for gear but no result, feels no clutch has been press, after pumping the clutch and also engine get hot gradually the gear shifting get normal even in excellent condition.
Now the questions is,
1) its normal for few days after changing the kit of master and slave clutch cylinders ?
2) should I change both clutch cylinders and clutch plates ?
3) should I check slave cylinder movement on cold engine by pressing clutch.
