I have a Nissan b11 with QG18de wire driven engine.
Once timing chain adjuster broke so i replaced the whole timing kit.
After that the engine's cam got rubbed because of timing chain issue so it had little bit of noise.
Petrol consumption was however around 11-12kml on local. I had pump issues so replaced it with a walbro.
Enjoyed the car's immense acceleration on walbro.
But after sometime it's filter got choked so i installed a new pump. That was now of altis. It was kabli and when i shook that pump it was like sounding something broken in it. Anyways i installed it. But my car felt like immense loss of power. And plugs were like orange.
So i again replaced the pump, got a walbro Gs 190lph.
It is a very good pump, gave good pressure. But what i I am facing is whenever i throttle the car suddenly. The car takes on rpm very slowly. And from idle to sudden throttling sounds as if the car is an v8. And I've replaced fuel rail, coolant sensor, air flow maf sensor, coils.
But still the issue is there.
My. Mechanic said the intake valve seat of second cylinder is loosened and parallel exhaust valve seat is tight. So he told me to go for new valve seats. Please suggest me what to do?
