its a nice car, 300E - not SEL.
its pretty easy to check this car, I would start with checking the undercarriage - specially the front ball joints because your car looks slanted to one side, you DO NOT want the lower ball joint failing as it has the potential to totally write off the car given the right circumstances.
The rear suspension arm links would be completely shot - thats for sure, along with the subframe and differential mounts and bushings. Once all are replaced and correctly tightened - you will be amazed at how this car can drive, It has a drive like no other machine that you will ever drive (except the W140 benz - they are hands down the last incarnation of true luxury car driving)
The engine is a 103 not 102. It faces head gasket failure every 7 or 8 years becuase of the dissimilar materials of the block and head - but is an extremely tough built engine, given the right oil and fuel the engine may survive you for the next couple of centuries.
How is the transmission shifting? smooth and firm shifts at the proper time? This transmission is very finicky about its ATF level and corecting the level is a true PITA if you dont read the fine print in the service manual (the automatic transmission service manual was never translated to english - hence the correct data for the various incarnations of the 722.3 gearbox are assembled as - pay attention to how it was assembled before) - the ATF level measurement from dead cold is not the cold mark on the dipstick - its 7mm below the cold (30) mark
If you do need any data google can help.
the transmission sump gasket is also a quirky setup but not that hard, just requires a fine low reading torque ratchet to tighten - overtightening causes leaking and so does undertightening.
anyway - enjoy the car and do the repairs correctly - do not just let your mechanic rip it
