Oooo yes another question
I keep reading this in threads that proper maintenance of cars dosent just require oil change. We have owned multiple cars now for short and long periods of time what exactly does proper maintenance consist of, I only own a manual for my motorcycle haven't consulted a car manual as of yet. But here's the things I did with our cars
1) alignment and tire maintenance
2)breaks with the disks being turned occasionally
3) coolant topping up ( although the level has always been maintained with no major loss of coolant like just a bit in a matter of months with recommended fluid )
4) oil changes with recommended oils
5) filters including AC
6) lights
7) belts when they got noisy
8) steering fluid leaked in my civic so that was fixed after the problem occurred
9) plugs
So what am I missing. What would include preventive maintenance.
I haven't gotten suspension work done much although I think one of our cars suspension is going a bit weak ? But it's still very comfortable and no noise but like a gut feeling that it's not as taut as it used to be. Mechanics say nothing is wrong which is strange cos they don't do any thorough checks.so what should be looked at.
Do modern cars require valve clearance adjustment ?
My passo had really bad fuel mileage 7/8 l/Km no one could diagnose the problem got the air sensor o2 sensor and everything checked with no luck now my uncles passo does the same thing. Really defeats the purpose of having the little car.
Aaand
We have two similar Corolla fielders, one of them had a relatively loud idle noise with the AC on. It's not some thing in particular but the combination of the fan and compressor is loud.. It's still chilled so no cooling problems , just that it's annoying to know that something might be going wrong , I got it checked mechanics said its nothing just characteristic of this particular car .
Sorry for the long post. But I find your guidance valuable
Regards
