@xulfiqar
I also have issue with diesel 2C. Yet to get Compression tested thought it was all fine 20 months ago.
1) Mechanic showed me piston moves inside its bore, like a play motion. This we checked when the head was open. Does this test means anything?
2) fuel efficiency is low, blow by gases there. Power is also low. Power improved bit when i timed pump with gauge. If i service the pump from typical diesel labs, is there a MOST Common Issues that i should check for?? Issues that may resolve 80% problem with 20% work or something like that. You know i cant expect perfection from these labs.
3) I feel my Pump timing point is too near the engine, it was RETARDED and had to be advanced. Is it possible to adjust PUMPS timing gear instead??? I want pump to be timed in the middle of its TO & Fro motion, that will probably put less stress on pump and timing will not get disturbed easily. What do u say??
Thanks and Regards
