what needs to be done in your car is to remove the dashboard and A/C unit completely - you will also need to remove the bonnet and mudguards/fenders/wings.
Now remove the wiring looms in whole pieces from the big connectors and lay out on tables and test/repair them with solder/heatshrink tubing and then loom them back. The wirings you will buy from scrap would be different than your car and in any case the dashboard needs to be taken out to install it.
Its not an easy task for DIY if you dont have the aptitude, if you are hiring an electrician then prepare to pay him quite a lot because it will take nearly all day of him - he will want all his days business earnings to work this.
When I used to rebuild G100 charades - every car went through this procedure but I didnt hire anyone as I was repairing the wiring myself. The original wiring quality of the cuore is terrible, very thin wires and poor looming because its a very cheaply built car. You will have to improve it and make it better - like plastic tubing and plastic tape for looming (dont use nitto tape, if you are using nitto then use some acetone to remove the glue first and seal the ends of the braid with silicone fusing tape)
practice looming on some junk wiring to get some practice, that way you can make sure your electrician/mechanic is doing a correct job.
