@xulfiqar
About to buy a facelift E53 BMW X5 with the 4.4i N62 v8 engine
I gather you are not a fan of Bmw v8s at all and people seem to suggest me the 6 cylinder models but it's been 6 months and all Bmw x5s I saw were terrible with owners maintained them from a ustaad in defense and don't even knew what oil viscosity ustaad was using and even that's the only thing they did oil changed no other maintenance
This one was a Bmw Dewan import as new from Germany and has full Bmw Dewan service history
I checked all the possible issues with n62 including valve stems(no smoke or oil reduction) clean engine bay all the valve cover gaskets seem fine the water pump has no leakage the underside is dry as a bone the coolant expansion tank has no leakage the radiator and all pipes etc are fine, I connected my autel maxidas scanner to it no errors or issues except one which said DME not found in engine electronics? Was that a issue with my scanner communication or with the car?
The guy just spend 9000$ on replacing the broken Panoramic sunroof, he also replaced some motor in the transmission a year back according to the service records he was telling me the name but I forgot he said Dewan said it needed a new gearbox but He imported that motor and replaced it at a independent and it's been fine ever since had no errors on my scanner and drove and shifted perfectly, spark plugs and ATF had also just been changed and BMW original engine oil and ATF had been used
Is there any other things I should check on x5s and particularly this engine ? Apart from the usual stuff I checked like the suspension bushings brakes etc car drives really well and pulls like a train
Only issue he tells me I might need to look at is that the AC clutch is making a noise but he says clutch can be replaced separately from the compressor and he didn't bother now as the AC is working perfectly infact it's working better than my Merc. He also only has one key so I have to factor in the cost of getting a spare key made from Dewan.
So is there any thing I need to further check?
I pray that it's no more expensive to maintain than the merc as keeping two German cars at the same time might become a issue plus the fuel economy is bound to be poor
Compared to a Honda vezel which I am a big critic of and compared to old prados with mostly kaabli parts installed I think this would prove to be better as I want to keep it for at least 6 years
