Thanks for the reply
Dewan diagnosed it as a intermittent fault in the voltage regulator on the alternator as well as a 5 year old battery according to the service history
The voltage regulator was giving a stored fault when scanned by BMW dedicated scanner although the car did not produce any electrical issue while they had it and alternator was producing 14.4-14.6V with engine running.
For now changed the battery for a cool 50k rupees and it has been fine till now if still face any electrical issue then they say to change the voltage regulator independently of the alternator
Also they diagnosed the bearing noise from the front as a faulty belt tensioner pulley instead of AC compressor after listening with a stethoscope
But just to confirm if the noise is not effected by turning off or on the AC it can't be the AC clutch right ? As I thought it was AC clutch but when they removed the shields and checked with stethoscope they were confident it was the tensioner especially as turning the AC on or off had no effect or noise though at the same time noise does not get much louder when revved.
