[QUOTE=khahsan;5201171]I ve suzuki baleno 2005
Car starts fine in morning.
But if stopped after when driven for 10-20 km or more then it does not start. Shows sign of a dead battery
However after 4-5 minutes starts instantly..
Checked battery and its fine...
What else could it be?
Symptoms of dead battery or low battery ?
If dead, it can be a corroded connection. But generally in case if it feels like a battery has drained low and starts after 4 or 5 minutes, that is probably because of starter (self). When the carbon brush or other self bushes are worn out, they tend to tighten grip on the internal shaft and needs more load when it is hot. After it cools down (in 4 or 5 minutes) it gets normal again. If that is the case, you just need to get your car's starter self serviced and replace it's carbon and other bush if they are found worn out. This job will take hardly one or two hours.
