xulfiqar bhai,Capsat or anyone plz help !
im facing a strange issue with my altis 1.6 2012...odo 107500
after 2000km after every oil change it starts to decrease engine oil and till 5000 it is consuming around 500 to 700 ml of engine oil...
there is no signs of smoke from exhaust,at idle,at cold start or anytime !
pcv valve changed bt the OEM was also working fine bt still the intake manifold is like sprayed with oil... fuel injector and air inlet valve are fully black with carbon or oil deposits!
did a compression test n all 4 cylinders result was 120-125 psi which is below normal i guess !
my again not even a very small amount of smoke observed... checked with radiotor cap removal no air bubbles appeared from there too...
what could be the issue ?
