@saboor73 @tintin1 @capsat yar temp rises to 65% during traffic jam only and fan comfortably brings it back to 50% again. What does this signify?
missing thermostat valve
Aisay he chalti rahi app key car tow engine seize kay chances hain boht zyda
Waterbody check karwaein
Ye aaj he se hona shru hua hai. Coolant se farq paray ga? Coolant temperature KO control me rkhe ga?
Coolant serves 2 purposes1) saves cooling system from rust2) raise boiling and freezing point But water handles heat better
Cooling system ki wiring check kraen , ac pe fan direct hota hai always . Agar cooling system thik hai to water pe b heatup ni Hoti car . Muje lag ra hai koi sensor kharab hai ya wiring issue hai , relay fan Wala change Kar k check Kar Len
But fan comes up OK when temp rises. Means relay is OK and wiring too
Means water doing its purpose. But it happens only once or twice whole day that too in traffic. And has started just today
@tintin1 the issue has started just from yesterday all at once. its showing overheating in traffic only and once car is moving its at 50% again - no issues. i suspect a bad water pump that is not circulating water as per requirement. as a precaution i plan to change it. what say?
I have changed the solonieds valve body located underneath the battery , with 3 small tube valves, car is very much better with soft shifting, now i am planning to change shift solonieds A as well to see if it will further shift softer
Dear , are you in Karachi I need to show you my accord 2002, please give me just a little time or may I have your contact number. . my number is 03002313104
can I have your contact number, ca n you please check my accord . it is a humble request I will pay you please03002313104 is my number
Hi, Is it safe to pour transmission oil in Honda Civic 2003 other than Honda ATF DW1? If yes than what are the options. Honda ATF DW price is 1250/liter and Honda ATF DW1 1440/liter whereas other brands like ZIC and Kixx ATF avaialble in range of Rs. 500 to 600 per liter.
A few possible reasons :
assuming the engine is good, valve timing is correct and valve seats r ok
please tell me can we meet somewhere in Karachi please guide me some good person I am willing to pay any amount to who ever solve my problem, please
