how to do it for baleno? how can i get a thermoswitch of lower temp rating? plz tell w.r.t karachi market
Fan is ecu operated on baleno
either way - the thermo switch sends the pulse signal for FAN activation.
yeah - so whats the solution for thermo switch of low temp rating?
locate & remove the thermo switch from engine it is close to the water flow intake & thermostat valve and replace with look alike size avilable for Mehran . Alto VXR READ THIS THREAD it may look like this with or without extended cable or grip plug
ok. means i buy Mehran's auto fan switch, install in my 2004 baleno? will it fit along with the wiring setup? so if all is done, will it turn ON the fan earlier i mean before 50% needle?
TEST is required for that , the temp needle is connected to temp sensor .
ok - so mehran's temp sensor will fit in Baleno?
It wont work with baleno wirring
@XulfiqarI am going to buy Suzuki Alto 2016 model.(Airbag Open). Car was minor hit right bumper.This car was not purchased from auction house.
Can any body tell me what things should i checked before buying this car.Specially how can i check ENE-Charge.
In japan pic
Karachi Port Picture
Today i tried to start my corolla 2010.it is making a clicking noise but not taking self at all. What does it mean a dead battery?
Seems dead battery . Check for electrolyte in battery , if level fine then check volts by multimeter. Next will be starter . Happened to me few times car wasn't starting and found that a cable dettached from starter .
It started after a little push. It seems like a starter problem or may be battery but battery is only 10 month old.
Get starter serviced if not done for long . Same situation happened with a friend in cuore and it was found a nut fell into clutch plate area hole while some maintenance work which caused jamming.Still get your battery checked , sometimes battery go bad quicker from heat or cold
Aoa salam.hope everyone is fine.i want to ask if Daewoo racer g15sf has TTY headbolts.if so where to find them in Pakistan coz TTY bolts seem alien to everyone. Moreover can non TTY bolts custom made can be fit into it.thanks
Sir plz guide me which oil grade is for EFi Cultus? API SG or SN 10w40?? SGO premium or Ultimate?
Still confused .. Plz tell me which oil grade is for EFI cultus .. API SG / SN / SL / SJ ?? Just 1 correct suggestion plz
Bump @Xulfiqar
