you bought your car with 325k on odo and when you sold it its clock was 300k. wat sorcery is this. meter reversed?
Both Xulfiqar and capsat have always responded me positively in inbox. both are always forthcoming. please avoid generalization of one personal experience.
btw i agree with you where short oil change interval is better than flush. I never did any flush despite fancy recommendations. Short OCI is better than flush.
lies have no feet ..
What is the recommended milage/duration after which company filled coolant and transmission oil be changed for corolla Altis 1.6 automatic 2018 model.I have this car since 2018 and not yet changed transmission oil and coolant. Both were company filled. Milage of the car on odo presently is 50000 km
The coolant lasts for 5 years. Transmission is either 80 or a 100k, will have to check
I have seen toyota red go stale after 3 years, its not as long life as other global formulas.
People also switch to dexcool in toyotas, it has a true 5 year life.
sir how to check if it has gone bad or still good.toyota is filling pink LLC here in pak.
I made a video, its on the other thread, use that but make sure that the mixture is 50% before this test.
Otherwise its invalid.
Please read the vdo description too
you should not be worried regarding wiring for led as its wattage is less. you should be worried for the fog lamp housing if it can withstand the enormous heat the led produces.
Is brake oil change necessary after 2 years?Paksuzuki recommends 2 years interval for coolant, gear oil and brake oilCurrent odo, 30K kms, and 26 months I'm bit worried regarding all Should I change all?
Brake oil yes, gear oil has a recommended mileage in the manual, read that and please follow it.
use toyota or caltex coolant, it is good for 5 years.
Gear oil , you follow the manual and use only suzuki oil
brake oil, yes it must be changed, it absorbs moisture from air and goes bad. but it is a specialist job not for gali mohallay ka mechanic
If i can do brake fluid swap half asleep,
Gali mohalla can also do it fully awake too.
Yes I don't trust local mechanicsEven dealership Can you recommend good mechanic in lhr?How's INH? Regarding gear oil, gl4 75w90 is recommended Planning to get liquimoly 75w90, tho it's bit expensive, about 2800/LSuzuki geniune costs 500/L (shell)Regarding brake oil, dot 3 is recommended, liquimoly dot 3 is available in market, better option?
Use toyota 75w90
Guard or seiken or toyota brake oil, all are equally good. No need for overly expensive LM , no benefit
Go to osama, his brake job is best in country. He is in garden town lahore.
03214106898
dont trust liqui moly too much is the best option...
original shell and seiken works equally good also
How can the output capacity in watts of a stator/alternator/generator of motorcycle/car be measured/calculated.Experts plz advise.Regards
Amperes * volts
