no its not.
i doubt any workshop in Abbotabad will be capable of doing it.
masla ye hai, first you measure the clearance with feeler gauge, then you go buy a new shim to get the clearance in range.
shims are supposed to be available with toyota dealers, but mostly nahee hoteen. you have to find them from scrap and check manually with micrometer.
then the part to install it.
Desi mechanic will try to grind valve stems or shims to get clearance in range, then the engine will get noisy
