I have a question I am trying to wrap my head around a car purchased recently suzuki hustler non turbo variant.
When it passes 50 to 60 on 4000 RPM to 5000 RPM it feels like the car is swinging. It goes forward and then stops and then starts going smooth again and feels like shifting to next gear.
One more thing, The engine is driven 170,000 Km, sometimes when the car is complete idle I cannot pass small speed breaker even when flooring the gas pedal, it feels like it is not moving at all and then eventually turning the ac off it goes forward very slowly.
I have tried changing sparks, done fuel pump change, did basic tuning and general tuning. did compression test, 105, 140, 140 respectively in the valves from left to right, I am thinking of doing engine flush with liqui moly to get the compression up.
Furthermore the oil that is being used it is 10w - 40. Transmission oil is fine as well.
One mechanic said that it's gear needs replacing. Can you please see and tell me what could be the issue here?
No engine check lights are coming up also
