Salam @Xulfiqar bhai, hope you are doing good.
I have a 2001 AT Honda City EXI-S with a swapped D16. I have been facing tapping noise that seems to be originating from the engine head, but can't figure it out if it's knocking or just tappets being noisy.
I got tappets tightened to the recommended spec, but the noise is still there.
Can you please guide me what to check or how to diagnose what the heck is up with it?
One thing though, the noise is insanely loud when the engine is at load i.e. I am inclining over a flyover in some higher gear, and as soon as I put a little pressure on accelerator pedal, so little that it just opens a bit of throttle for more air but not aggressive enough that ECU triggers a downshift, the noise goes insanely loud, and as soon as I lighten the pressure on pedal, the noise go away. And this pressure on the pedal that I am mentioning is very small, not even 100 revs change, but the noise gets louder with pressure along vibrations that I can feel in dashboard, and it's back to normal as soon as pressure is reduced.
What's up? Any direction or guidance will be really helpful.
Thanks!
