I'm sorry, but you didn't seem to answer my real question. Is Caltex Dexcool/Orange Concentrate a good subsitute for Toyota SLLC? And is AC water/ Battery water a good enough subsitute for distillate water? If not, please guide on a way to easily make distilled water in large qualitites.
As per your questions: (Method derived from TCCN Ahmed's guides and Toyota Manual as well as your advice)
For distilled water flush, will drain from Two places:
Radiator Drain Cock Plug
Cylinder Block Drain Cock Plug
Then refill, put car in Maintainance mode,
Before starting the engine, turn the A/C switch off.
Adjust the heater control to the maximum hot setting.
Adjust the blower speed to low setting.
wait till two fan cycles
Sorry for being vague about inverter, I intend to change it too:
Will change inverter coolant, still the factory fill. Under the transmission, a hex bolt is to be loosened. Will drain, then overfill till inverter coolant reservior nears max. WIll put car in maintainance mode. Two full fan spin cycles. Inverter coolant level will drop quick, so will add quickly as needed.
As always, feel free to correct me whenever I make a mistake. My first coolant flush.
