AOA, the pcv valve needs to be changed from around 60 to 80 thousand kms, this depends on the type of driving style you have. You can easily check if pcv valve needs replacing by spraying brake cleaner inside both ends of the pcv valve. the brake cleaner should only spray out from one side.
