@Xulfiqar for MB NAG1, How i pour Lubegard (atf additive) in trans, it is important if i drain same amount of atf of lubegard for correct level or just mix it as it is actuall level?
How much Lubegard required for 7.5 ltr capacity, 296ml whole bottle is enough for 7.5 fluid?
It is necessary mix it with new atf or can be use it with slightly used or good condition atf?
how about "Lucas trans fix" ~ "Slick 50 high millage auto-trans treatment" or which additive you prefer if lubegard not avail?
can i use both (Lucas & lubegard mix together) or which one as a substitute of lubegard?
currently using "Meguin Variable" in Nag1 722.6 which shift firmly , but "Meguin ATF smooth" 236.12 ~ 236.14 was really very smooth.
just it changed for 236.10 requirement, not found shell 3403 m115, only found shell s4 3403 no "M115" mentioned,it was in drum at a shell dealer, don't know it will good or worst for MB 722.6?
But i prefer "Meguin variable" from direct importer, (LM-1200 & Meguin varible both are same)
