The 722.6xx takes a highly friction modified ATF based on the Dexron III-H specification. The meguin variable product works too (not 100% perfect though - think of it as 95%). its suitable for all specs from 236.1~236.11, There are a bunch of other ATFs that work but are sort of hard to find in Pakistan. Pakistan has the problem of "aail aail hota hai"
the cheapest solution around the world is to use Shell ATF 134 but its pretty hard to get in Pakistan. Another solution is to blend some synthetic Dex 3 ATF with some modifier like lubegard HFM (still pretty hard to get)
I personally used two products in Pakistan. shell spirax3403 (got it from dubai) and some lubegard products which were used to blend ATF (mobil1 etc) for compatibility. Customer's choice as one was pricey and one was cheap.
