Originally published at: https://www.pakwheels.com/blog/attock-petroleum-ltd-offers-top-quality-lubricants-in-pakistan/
Choosing the right lubricant for your vehicle is the key to its engine health. Properly lubricated engines are the healthiest, and healthy engines perform the best. Whether you own a motorcycle, a petrol or diesel car, or an industrial vehicle, you can never go wrong with Attock Lubricants.
Attock Petroleum Ltd. has 700 retail outlets across Pakistan. Their wide range of lubricants and oils take car of all vehicles, “Jaisay Koi Apna”. Let’s go through all the Attock lubricants and see which one’s the right fit for your ride.
Attock Motorcycle Oil
Attock HiDrive 20W-50 is a high performance JASO MA2 compliant motorcycle oil. Suitable for all motorcycle engines, this oil is guaranteed to enhance the engine performance. It creates a film over the moving engine parts and protects them from wear and tear. It keeps the engine healthy in all weather conditions. The Attock Motorcycle Oil is available in 0.7 and 1-litre packings.
Attock Petrol Engine Oils
1. Attock HiDrive Advance SN, 10W-40
Attock HiDrive Advance SN, 10W-40 is the best quality oil for gasoline passenger car engines. It keeps the engine clean and protects the parts from rust and corrosion and wear and tear. It also enhances the overall performance and fuel efficiency of your car engine.
2. Attock HiDrive Supreme SL/CF, 20W-50
Attock HiDrive Supreme SL/CF, 20W-50 is another gasoline engine oil perfect for high performance engines. This oil is specially designed to maintains oxidation and thermal stability. It works the best for eninges operating under high temperature.
3. Attock HiDrive Super SG/CD, 20W-50
Attock HiDrive Super SG/CD engine oil is best for older petrol engines with SG/CD, 20W-50 oil recommendation. This oil brings old engines back to life and you can feel the engine rev on startup.
All petrol engine oils are available in 3, 4, and 205-litre packings.
Attock Diesel Engine Oil
1. Attock Gold Turbo Ultra CI-4/SL, 15W-40
Attock Gold Turbo Ultra CI-4/SL, 15W-40 is best for excellent lubrication of diesel engines. It protects the engine from wear and tear and improves the fuel economy.
2. Attock Gold Turbo CF-4/SG, 20W-50
Attock Gold Turbo CF-4/SG, 20W-50 is perfect for diesel engines that operate under extreme conditions. It prolongs engine life and lowers maintenance cost.
3. Attock Gold CD/SD-50
Attock Gold CD/SD-50 is best for older diesel engines. It creates a protective film over the moving engine parts and prevents wear and tear from severe temperature.
All diesel engine oils are available in 4 and 205-litre packings.
Attock Industrial Oils
Attock Lubricants has a wide range of industrial oils to help improve engine reliability and durability and reduce maintenance costs. They maximize the engine potential and keep it in its best form.
Keep your car engine clean and healthy with Attock Lubricants.
