InshAllah will post those once parts are installed. As of right now though a string of bad luck hit me. The pcv system (common to get clogged on these engines) got clogged causing excessive pressure build up in the crank case. the pcv system/ oil separator is easy to replace and cheap. I'll diy it and document the process since the method is the same for all vw/audi group cars made after 2011 with the 1.8/2.0 turbo engines. Including our Pakistani A6's.
The reason I know its clogged is the real bummer though. The rear main seal is seeping oil so I'm slowly losing oil, It is critical and needs to be replaced ASAP.
I like to think positively though and I'm looking at this as part of the ownership experience/struggle.
