When color of transmission fluid turns brownish,it means there is a slippage in transmission,when the transmission fluid get hot,it starts becoming thin.Such an action disturbs the pressure levels of the fluid,which causing transmission to slip, and that is why you are getting jerks.So it is better get it checked thoroughly, why fluid pressure is dropping, Otherwise your transmission will be ruined.
