AOA, I have tried to install automated trunk opening mechanism in my Corolla 2010. This project is divided into 2 parts. Links to the project are in the end.
- Electrical.
- Mechanical.
Electrical:
We have to use car security system so that trunk can be opened via car remote. For this we need to install a motor in car trunk (Image 1). Every car security system has a function i.e. when it's unlock key is kept pressed after it has been unlocked, it will send a signal to left bit which can be used even otherwise. I have used this bit to trigger car trunk motor.
Mechanical:
I have tried variety of springs for this project because we need potential energy for opening of the trunk. Hence when we actually close trunk it requires a bit more effort and that is moment when actually potential energy is stored in trunk for next opening. Whenever unlock key is kept pressed for 3 seconds this energy is released from spring and trunk is opened. (Image 2).
Cost:
Springs - 1415 (A pair, although I have used only one but I will use second one in my other corolla).
Motor - 200
Electrical wiring - 100
Etc - 100
Pros & Cons:
I need to adjust this spring since trunk is opening with a lot of momentum. I have made a dual adjustment myself for this.
Note: I have copied this project initially from YouTube but then later I have added some of my own alterations in it. Links are below for further information.
https://vimeo.com/user101990032/review/358559300/123f5d0adc
https://ibb.co/mDHHgyK
https://ibb.co/Fg7nvjC
