What are some of the common causes of the code?
Causes for this P0773 transmission code may include:
Insufficient fluid level Dirty
contaminated fluid Dirty
clogged transmission filter
Defective transmission valve body
Restricted hydraulic passages
Transmission has internal failure
Faulty shift solenoid Corroded
damaged connector Faulty
damaged wiring Faulty PCM
What are some common repairs for this code?
Changing the fluid and filter Repair
replace a faulty shift solenoid Repair
replace defective transmission valve body
Repair or replace defective transmission
Transmission flush to clean passages
Cleaning corrosion from connectors
Repairing or replacing wiring Flashing or replacing PCM
Source: https://www.obd-codes.com/p0773
