ASSALAM O LAKUM Hi everyone. I want to confrm that i am searching for an axio but my friends said to me that dont buy an Axio it has gearbox problems. Is it true. And someone said that it may be the cvt problem. What is the problem?
There is no problem, if cvt oil is changed on time, there is no issue
Can You please confirm Me that how i know that the oil is changed on time, and on how much kilometers the oil needs change.
common....the one who told must be kora kaghaz......
axio is one of the best cars ....go and check with any body i market, from any mechanic etc.....
oil needs to be changed every 40,000km, simple, lift the gear oil dipstick and check the oil condition
No basically axio transmission gets ruined if someone puts in ATF in it, it needs CVTF. Most of the illiterate mechanics donot know whats cvt or whats at. One of my friends went through same thing on his mira 660cc where a local mechanic poured toyota atf but car was cvt. Transmission got busted in 10 days eventually he had to replace it.
k3103 axio 2007 mokamao video market
Dear brother axio main dipstick hoti he nahi hai balkay jitnay bhi CVT gears cars hain un main dipstick nahi hoti
Hoti Hai, axio ka nahi Pata par passo, vitz, alto, sab may hoti hai
AoA expert opinion required. Meray ak friend ki axio ka axle mai problem tha he change ot with a kabuli one and also change CVT transmission oil with recommended cvt oil. But abi gadi tora chalany k bad jab gadi garam hojati hay tho gear kam chor deta hay or reverse gear mai both katarnk jarak marta hay.
Could need calibration
