Have been in search of a good mono to be powerful and clean enough to pair with my darling sub. And one fine evening me and my partner in crime saw this baby on the infamous hall road and bought it eyes closed. I get a lot of people saying hall road is full of desi stuff. I tell you, you just need to look a little more carefully and be gutsy enough to get down and dirty in the storages there, its a goldmine
JVC KS-AX6801 Digital Mono Power Amplifier 1200W Max
KS-AX6801 - Connection and Operation Selector switches and controls are all located on the front for easy operation and maintenance and covered with a protective window.
The KS-AX6801 amps look as powerful as their output figures suggest, and let you crank up the enjoyment for your next cross-country trip or just cruising around town.
Features
MOS-FET Power Supply
RMS output: 1 x 1000w @ 1 ohms
RMS output: 1 x 700w @ 2 ohms
RMS output: 1 x 400w @ 4 ohms
Max Power: 1200w
Frequency Response: 20 - 300Hz
LPF (50-300Hz. - 18dB/oct)
Subsonic Filter (20-50Hz. - 18dB/oct)
Variable Bass Boost
Variable Input RCA Level Control
Gold-Plated RCA Terminals
Gold-Plated Block Terminals
Thermal/Short Circuit/Overload/DC Offset Protection Circuitry
Anti-Pop Circuit
Control Panel on Top/Cover
LED Illumination
Weight 7kgs
Remote Bass Level Input (RM-RK130 required)
