Aoa guys. My altis 2015 shakes/vibrates at 100km/h speed. I shifted my front wheels to the back and vibration shifted to 115km/h. How to tell if its a bad axle or a bad wheel/rim that is causing the problem? I have got the wheel balanced and aligned
Axles dont usually go bad so soon. Get the wheels realigned from a better shop. And check your suspension bushes etc
Wat kind of vibration?Is it wobbling?Steering shaking?Can u feel vibrations on pedals?Wat happens if apply brake?Wat do u feel when u accelerate?
Have u cross changes wheels?How old is rubber?Wat sort of balancing u have dont and how much weight used?
Wheels were removed and balanced. Tyre was spun and weights were added. Front wheels were shifted to rear and rear to the front. How since this caused even more wobbling so the wheels were moved back to their original positions. Suspension is fine as recently work was done. Vibrations come only as car crosses 100. Behaviour on brakes waghera nahi check kia
to me it looks like balancing issue, how many kms tyres have run? how many yrs?
was a high speed balancing job was done adding weights both inner n outer rims?
