Bajaj has launched its new 135 cc bike, the Pulsar 135LS in India.
Price: Rs.51,000
Bajaj Pulsar 135 LS Features
More power: The 4 valve provides for a greater intake and exhaust area resulting in more power, almost equivalent a 2 valve 150cc engine.
Sustained top end power: The light-weight character of the four smaller valves (as opposed to two heavier valves), which allow the engine to effortlessly rev to an eye-popping 10,500 rpm (electronically limited)!
Sporty ride: Given the wider rpm band, the engine can be revved hard and high in each gear resulting in a genuine sporty ride.
More Mileage: Established superiority of DTS-i blended with 4 valve not only enhances the performance but also returns a very good fuel economy (68.1 km/l certified by ARAI)
More green: Comfortably meets BSIII regulations.
Bajaj Pulsar 135 LS Specifications:
Engine Type: 4 stroke, air cooled, 4-valve, single cylinder, SOHC, DTS-i
Displacement: 13.66cc
Max Power: 13.5Ps @ 9000rpm
Max Torque: 11.4Nm @ 7500rpm
Starting: Kick + self start
Front Suspension: Telescopic front fork with antifriction bush (Stroke 130)
Rear Suspension: Trailing arm with Co Axial Hydraulic *** gas filled adjustable shock absorbers and triple rate coil spring
Front tyre: Tubetype Unidirectional 2.75 x 17″
Rear tyre: Tubetype Unidirectional 100/90 x 17″
Fuel Tank: 8 liters, 2.5 liter reserve (1.6 liter usable)
Headlamp: 35/35w
Wheelbase: 1325mm
Ground clearance: 170mm
Kerb Weight: 122 kgs
Handlebar: Clip-on
Speedometer: digital with tachometer as analog display
