Aoa,
Probably a noob question so apologies in advance.
I have baleno JXR 2004 1.3 efi.
Now recently I had engine heating issue. I went to Mechanic in G11, Islamabad. As per ustaad g the block of engine is rotten(gal-sar gaya ha) because heating issue was building up but it finally came on surface after it had already done the damage to block. For temporary jugar head gasket was changed and magic depoxi was used to seal the block and rotten places, and ustaad asked not to use AC.
Ustaad said without AC you can drive it for next 6 months max and either change the block (estimated costs around 60k to 75k) or swap the engine with kabli baleno engine (estimated costs around 160k to 180k).
Please note current engine has completed 380000 kms.
Please advise to change the block or go for swap. And also which markets are advised for either of options. My radius is rwp to peshawar.
Looking forward to gurus advise.
