Car stalls when taking a sharp left turn and when I try to start it sounds like the battery is not charged...actually doesn't even start no matter how many times I crank until I completely turn the switch off and try again it starts right up, this started happening right after getting axles work done...is it possible if crank sensor wiring is touching with axle and causing sudden engine stall?
