Dear All - AOA ( From Karachi )
i have just purchased Baleno 2001 EFi ( Petrol only - Engine replaced with the same model 1.3 L ), first 15 days it was running perfect with AC, then it started to loose RPM and shut down as i start my AC.
i went to mechanic he simply cleaned the throttle body , changed its RPM sensor ( Took 1500 ) and it worked well, after 2 days again it started to loose RPM as i on AC, then i went to another mechanic he fully tunned the car and advise to change its RPM sensor and the issue still not solved.
then i went to another mechanic after 3 days , he checked and said that it ECU is faulty and need to replace ( used from sher shah) with cost 10,000 approx. then i left car at his work shop, in evening he told that problem is solved and the same card repaired ( cost 6,000 ), now it worked for 1 week and then again same problem started
and as of today the problem is as follows.
1- As i start engine it start take speed and then comes at normal ( without AC ) suddenly it looses RPM and car start to jerks and check engine light gets on , then after 1 -2 minute check engine removes and comes at normal then again the same check engine appears and then car gets off.
its new engine ( kabuli ) CNG never installed .
Can any one guide me what should i do now or any honest and perfect who takes money at least earn halal and sincerely solve the problem.
