hi, my baleno's radiator has gone direct. turning on the ignition also turns on the radiator fan. is it the heat sensor which is faulty or some thing with the ecu. plz help me out
Sir check your thermostat, nothing wrong with ECU.
thanks dear, i have taken my car to sethi motor. everything came out to be fime, just a minor shortage in the fuse box.
I told you in another thread the same that there's somthing wrong with the grip of your car's fan or some thing short circuiting.thats good you found out the problem.cheers.
salam broi have baleno 2004 its going extreme heat while drive with ac, please help
Is it a bad thing if radiator fan and condenser fan is direct? Same is with my car as soon as i turn on ignition both fans start...
