Aoa,
My Car is Baleno 2004 running on petrol and my car taking long self when its cold and morning start.
(Switch off kar ke 2 ya 3 hour baad start karta hoo tu phr self lamba lete hai but start ho jate hai aur agar shorter time ke liyee band karta ho tu foran start hojata hai)
Also sometimes black smoke appears then my car is missing problem and sometimes black smoke won't appear and it works fine. I went to the electrician to check this issue and he checked map sensor and it's fine but map sensor wiring cutting on someplace and electrician said its an engine wiring issue it need to change all engine wiring and then I scan and check all sensor. Currently, I cant able to check because of rough cutting wiring.
Car zayada problem nahi karahe hai bas starting lambe lete hai aur kabhhi black sjata hai but woh chala jata hai wire map sensor wali side se hilane se kyaa mujhe pore wiring change karwane chayee ya just map sensor wali side wiring ko repair karon??
