Hello Friends,
Just wanted to share with you the basic modifications i did to my CL9.
Installed a 22mm Rear Sway bar which replaced the stock 11mm sway bar. Noticed a change in handling on corners and now can turn corners at more speed compared to the stock.
Second mod. i did was to install Hondata Intake Manifold Gasket. Still need to do more trial to see whether the below claim is true or not !!
"Hondata have developed a special high temperature insulating gasket which replaces the stock intake gasket. This and bypassing several heat sources significantly reduces the transfer of heat from the head to the intake and incoming air giving you up to 3 to 5% more power."
"For every 3.3 °C (5° F) rise in intake temperature, air density drops 1%. The hotter the air, the less fuel the computer injects to compensate for reduced oxygen"
Stock Parts
Hondata Gasket
22mm Sway Bar
