Bath Master by HomeCraft
With an all plastic construction the Bathmaster Bathlift is easy to clean and maintain, and is strong and robust ensuring complete stability. Sufficiently lightweight to be easily manageable, it fits into the bath with the minimum of effort.
This has been designed to provide a comfortable and supportive bathing position which may be further enhanced with the addition of the optional pads. The single button operation allows the user to descend and keep the backrest upright or to recline back to a more comfortable position, whilst retaining ample leg room to relax in the bath.
The hand controller incorporates a superior battery delivering market leading performance. It incorporates a host of useful features, including audible and visual alarms to signify operation and battery charge levels, and a handy sleep function to preserve the battery life.
Key Features and Benefits
Modular and portable, a two piece powered plastic reclining bathlift that fits most shapes and sizes of baths
Sucker feet that may be angled in any direction to suit the curvature of the bath to ensure stability and safety in use
Contoured seat and backrest for support and comfort. May be used with or without the covers
Two lightweight components that simply click together facilitating quick and simple assembly, installation and removal
Designed with convenient holding points on each component to ease carrying and transportation
Large side flaps to allow easy transfer on to and off of the Bathmaster
Easily operated by lightly pressing the large control pads, which are textured to assist the visually impaired
An audible bleep and warning light identify when the battery requires charging, and when to stop using the bathlift.
This helps users to ensure the battery is always charged and improves its reliability and performance
A built in safety mechanism ensures the bathlift will not lower if there is insufficient charge in the battery to raise the user
Smooth steady action plus a transition interval between reaching the base of the bath and reclining allows the user to remain in a controlled position increasing confidence and security.
The preferred angle of recline can be selected by the user enabling the most comfortable and suitable position to be chosen
Price PKR 11,000.
Contact 0345-8508553
