Battery Basics: A Layman's Guide to Batteries
The lead acid battery is made up of plates, lead, and lead oxide (various other elements are used to change density, hardness, porosity, etc.), with a 35% sulfuric acid and 65% water solution. This solution is called electrolyte, which causes a chemical reaction that produces electrons. When you test a battery with a hydrometer, you are measuring the amount of sulfuric acid in the electrolyte. If your reading is low, that means the chemistry that makes electrons is lacking. So where did the sulfur go? It's resting on the battery plates so that when you recharge the battery, the sulfur returns to the electrolyte.
tap the link for more exposure to issues
