I want to buy a battery charger with equalization mode in it. I have searched market as well as internet. No such product is available in Pakistan. Any idea? Branded / non-branded solution for this?
Or if there is any desi method / jugaar?
A charger with fixed voltage output (say 15.5V~16V) for continuous charging contrary to a normal 2-stage or 3-stage battery charger which cuts off charging on a certain stage?
Also such charger should have low ampere output (<1A) to fulfill the requirement of battery equalization and to avoid over-heating of battery.
Or a charger with variable / adjustable voltage and ampere output?
I have a 12V Lead-Acid Phoenix battery (UGS-215) with Homage UPS. I've been using the battery for over a year and now want to apply equalization charge to remove sulphates and to equalize the cell volts.
Any suggestions will be welcomed.
