The issue started after I changed the battery but I'm not so sure that was the cause of it. Once I changed the battery, after a week, the fan wouldn't switch off when I switched off my car, The key would be in my hand and the fan would keep running. I had to take out the negative terminal to switch off the fan. When I took it to the electrician, he said it's the relay problem and changed it and it fixed the problem. Since then, the fan immediately switches off but the engine takes like 2 seconds to completely shut off (kind of like how your car shuts down when it runs out of fuel). This has never happened before and I'm not an expert but I feel that some current keeps it running or something. Idk.
Are you saying that the daewoo battery might be leaking that 0.4A or that it has a very low capacity? The battery doesn't drain if I take off the negative terminal
