I was also facing same issue, current was getting drained from the dome light circuit. When I took out that fuse, all the dome lights & door warning lights went off, battery drain amperes came to normal 0.02A.
In order to rectify the issue, I check all 4 door jamb switches but they were fine. Uninstalled the dome light assembly to check for any stripped wiring causing any shortages but to no avail.
Finally I asked my friend to get into the trunk & check if its bulb is still lights up after I close the trunk and he reported that its lighted up all the time, no matter you open or close the trunk, so here comes my issue resolved, the switch was malfunctioning & keeps the bulb on all the time, which results in battery drain.
After replacing that switch, my problem got solved. I will request you to check the trunk wala bulb by requesting any friend or your younger one's.
