If the meter is showing 14 volts when the car is turned on, it means that your car's alternator is charging the battery well and the battery also has the required volts when in the charged state, however, when the car is turned off, and the meter is showing 10 something volts, then the first thing I'll do is to get the battery checked, maybe there is some problem with the battery as the resting voltage of the battery has to be 12 something volts and not 10 something.
I hope it helps.
