@ khubaib
I may be able to help you but Im not clear on your requirements......
The super bug suspension does not have a 'Pitmann' arm like the non supers.....so what do you need???
Is it the universal joint shaft which connects the steering column to the steering box......or is it the small drop arm which goes under the steeering box or the idler arm which is fit to the LHS of the suspension setup in a rhd car???
It would be great if you could post pix of your requirements. Would make things easier.
I cant promise anything as according to what I know its been quite a while since a super was scrapped at shershah, karachis junkyard. Still u may be lucky if I find stuff lying around in the shops there.
Btw whats wrong with the part on your bug???
And I must complain that you are having work done on your car and not a post on PW to update us??????
Regards.
