Hi chinyoti, how are you?
I do mix hi-octane sometimes but the problem is still there. Re: gapping I don't think that's the issue as these plugs already come pre-gapped. Also this problem was occurring even when the stock japanese plugs were in there too. So I replaced the plugs thinking it would go away but no
Xulfiqar...i recently put new Denso Iridium plugs thinking that was the problem. How do I know if its low fuel pressure? When the car was scanned there was nothing as such. Someone pointed out that probably my fuel filter is plugged????
atif...I try to use mostly Caltex fuel most of the time and if not, then Shell.
Thanks post911....how do I check the generator? Will any electrician be able to do so?
