An Inverter compressor is designed to vary it's speed as the demands in the room change. Inverter compressors are designed to soft start therefore causing no dips in power supply.
The inverter technology is integrated in the outdoor unit. The inverter technology can be compared to the technology in a car: " The harder you push your accelerator, the faster you go."
An inverter unit will gradually increase its capacity based on the capacity needed in the room to cool down or heat up the room. The non-inverter can be compared with switching on or off a lamp. Switching on this type of unit will start to run on full load.
The DC inverters use Advanced Digital Hybrid (ADH) technology for better, smarter and more cost-efficient yearround climate control. Immediately following start up, the DC compressor operates at maximum power to provide almost instant heating or cooling. As the desired air temperature is reached, a special Pulse Width Module automatically adjusts the compressor's frequency to exactly meet the cooling or heating requirements of the room. The result is exceptionally precise temperature control, less noise and significant energy savings
Guys if u want to reduce your electricity bill upto 50% then go for split with dc inverter base compressor. Few Lg models have this technology but they assemble for those who order minimum 50 pieces.
check this lg model. it has dc inverter base compressor
LG AS-W126B1U1 Split AC - DC Inverter Technology, 3G Cyclotron Plasma, Allergy Care System, Jet Cool, Jet Heat, Hot and Cold Function - LG Electronics IN
