Waleed, are you referring to the main headlight bulb? If yes, I'm assuming it's a hs1 bulb? That's technically the same as a h4 (which can be used on the hs1 socket)
If you can pay the 4.5k price, I'd suggest you look into Auxleds. I've been using them in my cars. They come with 1 year replacement warranty and I've had one set which has been in use for 1.5 years and had no problems so far
Apart from that, you can also look into novsight, bi-led on Facebook etc. Note that the same wattage bulbs (55W) offered by them are more expensive than auxleds. They too offer the same 1 year replacement warranty.
I'd suggest you get one of these bulbs rather than the crap led bulbs (c1, c9 etc and many more) that are being offered in shops that have pathetic light pattern, no output and just the tinge of a blue/white light for sashka
