3 people in my neighbourhood bought Samsung ac .they developed mysterious problems within an year
Thats the most relevant answer...m getting confused
Which model of Mitsubishi u are using
Try orient 12k ecomfirt 1 tonn. Electricity bill is 3000 per month by using 10 hours a day. Air through is 50 ft therefore it cools two rooms. Cost. 44k without Wi-Fi. Wifi cost 10 k
Yes pls....exact model numbersAnd one thing more....ppl say that inverter acs arent successful in electricity saving due to load shedding.reason being that when ac achieve desire temp and drops running amperes.....in case of load shedding it will shut down and will again start on starting amperes....is this true
How have you measured wattage, I would really like to know. Usually all ACs will consume full power to quickly cool the room, if you want an actual value. Measure it after half hour of running
Can we do it by using sub meter?i have heard about sub meters but never used....do u have any experience?
Can u pls check mitsubishi MSZH-50VA model (1.5 ton)on ishopping.pk and homeshopping.pk.....ur opinion is required and will b highly appreciated sir
Jo bhi Lenae asal dealer se Lenae .yeh homeshopping aur is hopping walae used dabba kohl walae rakh ke bethae hotae ha
U r right in a way....i have bought many things from them and never got complaint.bought samsung automatic waahing machine,many cell phones.....
And also if u can check panasonic econavi there.....and compare both and suggest
No. Because it is type of compressor which is different in inverter AC. This compressor won't use same amp. It varies with the time n it independent on temp. When pressure achieved then it uses low current.
Ground floor,13 ×15 room size,roof at 12 ft,no false ceiling,moderate sun exposure
Dwellers may be 4 to 5,outdoor unit will b just outside the wall of indoor unit
I use Panasonic inverter ac It normally takes 1.5 to 4 AChilling air Fast air flow
Which model
panasonic ac cs-k18pkf
