is 1jz non turbo is suitable for pajero 5 door with CNG. use only in city.. how much it cost me in lahore???
wats the best engine swap for 89 model SJ410 keeping it mind if its a daily runner?? Please advise
best engine for SJ410 is 1.3 TOYOTA ENGINE (EE90 or INDUS COROLLA engine)
BALENO 1.3L engine is also very good
note: FOR RELIABILTY N COST EFFECTIVENESS USE CARBURATOR TYPE ENGINES ONLY
happy altering =)
A 2UZ is no better than a 1UZ in terms of power. Put in a 1UZ with a CT26 Twin Turbo setup and see it fly!..That high revving V8 with open exhausts is literally music to the ears.
The 2UZ is better because it is low reving engine so you get more life and most importantly, It is designed to produce most torque at lower rpms so its more suitable for SUV applications. That means on 1UZ you have to push the throttle harder for same movement that 2UZ can do at half the throttle, hence efficiency and fuel economy.
I'm sorry i didn't clarify the intent of my post. It was more from a fun point rather than a realistic approach. Sorry about that.
Hi, did you actually get the 1uz and how did it work out for you? I'm about to swap the old gutless 2lte out of my surf 93 with either a 5vz or a uz(either 1 or 2).
What engine would you suggest for a FJ62 Land Cruiser (5 door model)? Would the 1UZ be best for this vehicle? Would it be best to change the transmission as well or try to mate the original manual transmission with the new 1UZ engine?
if you get 2H in standard bore it would be ideal for your FJ-62
Hi everyone
I have Toyota surf 2004 model looking for 1GR-FE engine.
