I go from charsada road near northern by pass to chrsada through GT road nt motor way so most of the time i drive btw 50 nd 60..ur route is congested... I think ur milage is not bad keep in view of the university road rush.
hmm i guess so.Whats the tyre size and psi.Mine are 185/65/14 and 30psi all four.
Oh i read it 575.. It shld be at least 500
Same as urs.. And i fill wth 31psi
Check balance and alignment too.. Do u accelerate frm start.. I mean jackrabbit... I usually press accelerator very slowly for initial 10 to 15 secnds..
I did everything,alignment and stuff.yes its 375km compared to yours.600km is too much.It cant even do 400 let alone 600.Any tips?
U have done almost everything i did... Try to gve little time when moving frm start nd dnt push hard.. Slowly gain speed.. I hve still dead weight of 55kg cylinder weight.. Insha Allah wl remove it also.
I tried that. Accelerating very slowly, max I got 395km. Before I got 375 on a full tank with regular somewhat jackrabbit driving.
Hmm, wht else cld be th reason... Plugs, or perform engine compression test..
I just dont know what to do anymore.
Engine compression test?
By compression test they check each cylinder psi.. Do u use cooleant or simple water... I use guard cooleant.
One more thing i fill from total, try different filling station.
No coolant, simple water. Where did you do engine test? Also which Total station, location, please. I filled from shell and pso only.
simple or high octane?
I fill frm bukhshipul charsadda road, i dnt hve gd experience wth pso.. I didn't done it nd nt sure who do it peshawar except Toyota centers, but thy r vry expensive.. If u cn ask from sme workshop near tehkal.. Thy may knw..
I use regular, simple..
I will fill with total this time on refill.PSO is the worst.I got 280km tank full.Havent tried total yet.
PSO are tugs.. Share ur experience then..
Bro what spark plugs do u have in your Vitz?I wtnt to Chaudry..they didt't have official K16RU instead they gave me K16RU11 which are for 1300cc.any idea?
