6 year old thread people....... the guys moved on
sealing a door isnt that hard. the main area where the water leaks in is through the window rubber slits. that can easily be fixed and so can any holes. u need to leave the ones at the base open so that if even if there is moisture inside the door, it can drain out of there. also if u can make fiberglass pods, placing speakers in the doors is not a big issue either.
however it should be made sure that the doors aint leaking water first.
